2020-01-16 7:08 AM
I have several projects in SPC5Studio and I want to have common files shared by them, in order to modify these common files only once. So I'm trying to use linked files.
I have introduced a linked folder in my project by selecting:
New project/Advanced/Link to alternate location (Linked folder)/Browse
The folder is included as linked folder. The problem is that when I build the project I get an error, because common files are not found.
What am I doing wrong? Is this the right way to have common files shared by several projects in SPC5Studio?
Thank you in advance for your help.
2020-01-28 9:04 AM
Hello Fespo ,
I think that it is a eclipse question..
Makefile should be updated.
you should update user.mak makefile to access to your virtual folder.
For common codes , in our development environment (git) , we are using some hooks or git submodules.
it is working well
Best Regards
Erwan
2020-01-28 9:04 AM
Hello Fespo ,
it is working well
Best Regards
Erwan
