SPC58xNxx PWM Generation with TOM (AN5552 Application Note)
OrhunNiso
Hello, on SPC58xNxx board, I've been trying to generate PWM signals using Timer Output Module (TOM) and I followed this guideline:
AN5552: https://www.st.com/resource/en/application_note/dm00730101-generate-pwm-signals-with-gtm-stmicroelectronics.pdf
The only difference between my attempt and the guideline is that I used another TOM channel & pin to output the PWM signal. However, I cannot see any oscillation on the Logic Analyzer. I already checked the Logic Analyzer and in another project, I could see a live signal on the same pin.
I attached the project as zipped and I need some support about this problem.
0 REPLIES 0
