2019-03-13 5:55 AM
I do not quite understand paragraph 29.3 "Modes of operation" of RM0045 Reference Manual for SPC 56D Line MCUs. It says:
NOTE: This question and answer originated from a customer support case which was handled by us. We regularly review support cases and add any helpful ones here for all to benefit from.
2019-03-13 5:55 AM
1) You should activate the register protection of the safety related registers.
There are 2 possibilities to protect the registers either with hard or soft lock protection:
From the safety standpoint, the hard lock is a better choice because even if the software "gets crazy" it can't remove the lock.
2) Yes, the user can read the source of the last reset by looking at the status registers of the RGM, FES and DES.
2019-03-13 5:55 AM
