Is there any evaluation board or starter kit using the component L9678P-S ? Target application is airbag or pyrotechnic fuse.
FPhil.11
Oh, I see now where you got that information.
However, the L9678-S-EVB mentioned there is not a generally available tool. If you need it, please contact your local personal contact person at STMicroelectronics directly.
/Peter
Peter BENSCH
Welcome, @FPhil.1​, to the community!
No, there is currently no evaluation board for the L9678P-S.
For further questions about this component, please contact your local distributor or the local ST office.
If the problem is solved (at least for the community), please mark this thread as answered by selecting Select as best, as also explained here. This will help other users find that answer faster.
/Peter
FPhil.11
Hello
In fact I found an Evaluation board for L9678 airbag and battery cut-off IC on your website (see UM3144).
/Peter
