2020-03-13 8:06 AM
HI all,
I am Ragu, and I need to flash SPC560b50l5 chip using SPC560b54l5 discovery board. I use PLS adapter setting in document as they mentioned but it not works?.
Below I attached JTAG connection circuit diagram which I use. I probe the JTAG pins with CRO and I confrim that data transfer is takes place from spc560b54l5 discovery board but spc560b50l5 controller is not respond after flashing. I need to know why it is not works. I think it maybe not flash correctly, isn't it? I any one face this issue, Please help me.
With Regards,
P.Ragu.
2020-03-16 3:35 AM
Hello Ragu ,
there are some examples in SPC5Studio Application Wizard
You can check this application
SPC560Bxx_RLA Bootloader Application for Discovery
Best Regards
Erwan
2020-03-16 3:35 AM
Hello Ragu ,
Best Regards
Erwan
2020-03-16 10:29 PM
Hi Erwan,
Thanks for your quick reply. I am working on it.
With Regards,
P.Ragu
