2020-02-07 5:21 AM
Is there any hardwade design guideline for SPC58 like there is AN3024 application note for SPC56?
There is a lot of power supply signals in SPC582B...E1 and very little grounds...
VDD_LV_FLA
VDD_LV
VDD_HV_IO_MAIN
VDD_HV_ADR_S
VDD_HV_ADV_S
VDD_HV_OSC
VDD_HV_IO_MAIN
VDD_HV_FLA
VSS_HV_ADV_S
VSS_HV_ADR_S
VSS_HV_OSC
Which should be connected and which not?
I found it strange that there is no ordinary ground signal (different than in SPC56). Which ground is THE ground? OSC?
In SPC56 I had to put decoupling capacitors between adjacent VDD_LVs and VSS_LVs. But in SPC58 there is no VSS_LV and VDD_LV is far away from any ground pin...
Thanks in advance,
Yannek
2020-02-07 5:46 AM
Hello Yannek ,
I am checking in the documentation database in order to find the document requested.
Best Regards
Erwan
2020-02-12 7:34 AM
Hi Erwan,
Any update in this topic, please?
For me it would be enough to know which pins should be tied to VCC and which should have only capacitors connected.
Best,
Yannek
2020-05-08 3:38 AM
Hardware Design Guide cannot be released on a public forum.
Please contact ST Sales representative for your Region.
