2019-01-01 7:51 AM
Hi there
I'm working on a spc5studio project which one of my friends has worked on it. when I open the project in spc5studio, I get the following error message:
Error: Unable to find component plugin named 'com.st.tools.spc5.components.platform.spc560bcxx'.
Please try to install it from SPC5 market place.
Neither can I generate application code nor I can compile my application via SPC5Studio.
I couldn't find any plugin called 'com.st.tools.spc5.components.platform.spc560bcxx' in internet. what is the problem?
thank you all
2019-01-10 2:18 AM
Hello sdrad ,
You should install the corresponding device from
http://download.spc5studio.com/updates/
Best regards
Erwan
2019-01-10 2:18 AM
Hello sdrad ,
Best regards
Erwan
2019-01-10 2:32 AM
Hi Erwan
thanks for your response. There was some other plugins that were needed to be installed. I found them in the market place section in help menu and when I tried to install them I encounterd some errors saying that the requested URL is invalid(or something), after so many failed attempts I realized that I must install plugins from the "Help/Install New Software …" and not in marketplace section. It looks as if the market place section have some bugs and nothing can be installed from marketplace. take a look at SPC5STUDIO market place in help menu...
