2015-03-28 6:27 AM
Hi
I want to use the Data flash for my information's , i correctly write and read on this section but my problem is when i want to write again on the same address i should erase all block but i have other information on that block . i read the (32-bit MCU family built on the embedded Power Architecture.pdf )(RM0017.pdf) in page 701 on EEPROM Emulation Section Wrote: The choosen ECC algorithm allows some bit manipulations so that a Double Word can be rewritten several times without needing an erase of the sector. how can i do this without erasing hole block and what can i do for this ? Thanks, Best Regards Vanima
