Application Import - file system
‎2015-05-11 11:38 PM
I am trying to import settings/files from another project to current project. I followed the steps as File->Import->General->File System and provide the path for source project and click finish. Tool is giving an error at the end of operation. Please find attached image for it. Please suggest the remedy for it. Thanks.
Mike.- Mark as New
‎2015-05-12 1:18 AM
Hello Mike ,
you have to import a project not a filesystem. Best regards Erwan- Mark as New
‎2015-05-12 1:56 AM
I have a project already created. just want to import few files to this project. Can't I import few files to existing project? Please clarify.
Mike.- Mark as New
‎2015-05-13 1:34 AM
Hello Mike ,
If you want to reuse some files in old projects , you should copy paste some files into your source directories or use some presets for same families. Best regards Erwan
