2022-01-29 8:32 AM
to decrease output noise, can I use 16db gain to drive 4ohm or 8ohm speaker with tweeter in low volume.
"Selectable gain 26 dB /16 dB (for low noise line output function)" in datasheet but no only shown.
2022-01-31 12:28 AM
Welcome, @YSun.7, to the community!
If I understand your question correctly, you want to reduce the output noise by setting gain to 16dB?
Yes, the output noise will be reduced, but also the volume by (16dB-30dB) = -14dB.
/Peter
2022-01-31 12:28 AM
/Peter
