TDA2003 going obselete
markrider9
Posted on March 19, 2015 at 12:02
Is there a replacement for the TDA2003 or can  any one recommend a similar audio amplifier that can drive loads down to 1 ohm?
#tda2003
This discussion has been locked for participation. If you have a question, please start a new topic in order to ask your question
Nickname1623_O
Posted on March 20, 2015 at 01:50
hi Mark ,
You may check TDA2009A , the output current capability is same with TDA2003 .
but TDA2009A is for stereo output configuration .
Thanks to consider ST device.
