Power dissipation and thermal resistance details required
VA.7
We are using "M41T80M6F" and "LM239ADT" in our design.We require power dissipation of this ic under typ,min and max conditions for thermal analysis.Also require "RθJB-Thermal resistance between Junction to Board",RθJC-Thermal resistance between Junction to Case ,RθJA-Thermal resistance between Junction to Ambient and Tjmax-Junction temperature.
 which is not available in the datasheet.Kindly help us to get the same asap.
This discussion has been locked for participation. If you have a question, please start a new topic in order to ask your question
Eleon BORLINI
Hi @VA.7​ , I suggest you to try to post the question in Analog And Audio community [added topic]. Regards
