pad burring on LMX358IQ2T
IReye.2
Hi!
I have LMX358IQ2T device that has burrs on the edges/pad.  I would like to know if this is OK to use.
Do you have any criteria on accepting or rejecting burr problems on non-leaded devices?
Peter BENSCH
If only a few devices are involved, they are certainly still fully usable with such slight damage (as I can see). For larger quantities or higher requirements you should contact the distributor from whom you ordered and purchased these devices with this question, who will then take appropriate action if necessary.
/Peter
Peter BENSCH
/Peter
