2016-02-04 4:53 AM
Is the tab or ''slug'' of E-TDA7391PD connected to anything? I'm guessing that it's connected to GND, but I cannot find any information regarding this.On the similar circuit TDA7391LV, it's stated in the datasheet that the ''tab'' of the ''Multiwatt 11'' version is connected to GND, but I don't see any information regarding the ''PowerSO-20'' versions.If it's not connected to GND. Is it okay to connect it to GND?Kind regards,Albin2016-02-04 6:40 PM
2016-02-04 11:07 PM
Hi YT,
Thank you! I guessed that this was the case, but I wanted to be safe since it will be hard to disconnect the slug-pad from GND once connected on the prototype. :)Kind regards,Albin
