IAR based project for STM8L and wake-up by AWU
infoinfo964
Posted on August 16, 2010 at 10:13
napoleoni.jacques
Posted on May 17, 2011 at 15:09
I suggest to use STM8L10x standard peripheral library available at
http://www.st.com/mcu/familiesdocs-120.html
 that can be adapted for IAR and including AWU peripheral.
nanayakkaraan
Hello AlexDion,
Am also having a similar problem.  I want to set registers of STM8L152C6 as follows and that is the syntax I am using.
But the registers are not get assigned.
TIM4_PSCR = 0x0A;
 TIM4_CR1 = 0x01;
 TIM4_IER = 0x01;
When debug values are not assign to registers.
Have you got any idea on this issue?
Any suggestions regarding this matter is appreciated.
Thank you.
