How does the function work? void Delay(void action(void), int NumberofTIMCycles); and how the NumberodTIMCycles always hold the value 10. while there is no declare any
Mkuma.12
 * @file main.c
 * @brief Adjustable LED blinking speed using STM8S-DISCOVERY touch sensing key
 * Application example.
 * @author STMicroelectronics - MCD Application Team
 * @version V2.0.0
 * @date 15-MAR-2011
 * THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
 * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
 * TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
 * DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
 * FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
 * CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
 * <h2><center>&copy; COPYRIGHT 2008 STMicroelectronics</center></h2>
#include "stm8s.h"
#include "stm8_tsl_api.h"
#define MilliSec    1
#define Sec      10
void CLK_Configuration(void);
void GPIO_Configuration(void);
void ExtraCode_Init(void);
void ExtraCode_StateMachine(void);
void Toggle(void);
/* Global variables ----------------------------------------------------------*/
u8 BlinkSpeed = 6;
int NumberOfStart;
int CheckFlag = 1;
/* Public functions ----------------------------------------------------------*/
 * @brief Main function.
 * @par Parameters:
 * None
 * @retval void None
 * @par Required preconditions:
 * None
void main(void)
 /* Configures clocks */
 CLK_Configuration();
 /* Configures GPIOs */
 GPIO_Configuration();
 /* Initialize Touch Sensing library */
 TSL_Init();
/* Initialize all the Touch Sensing keys */
 ExtraCode_Init();
 /* Start the 100ms timebase Timer */
 TSL_Tick_Flags.b.User1_Start_100ms = 1;
 for (;;)
  /* User code */
  ExtraCode_StateMachine();
 /* Main function of the Touch Sensing library */
  TSL_Action();
 * @brief Initialize all the TS keys
 * @par Parameters:
 * None
 * @retval void None
 * None
 u8 i;
 /* All keys are implemented and enabled */
 for (i = 0; i < NUMBER_OF_SINGLE_CHANNEL_KEYS; i++)
  sSCKeyInfo[i].Setting.b.IMPLEMENTED = 1;
  sSCKeyInfo[i].Setting.b.ENABLED = 1;
  sSCKeyInfo[i].DxSGroup = 0x01; /* Put 0x00 to disable the DES on these pins */
#if NUMBER_OF_MULTI_CHANNEL_KEYS > 0
 for (i = 0; i < NUMBER_OF_MULTI_CHANNEL_KEYS; i++)
  sMCKeyInfo[i].Setting.b.IMPLEMENTED = 1;
  sMCKeyInfo[i].Setting.b.ENABLED = 1;
  sMCKeyInfo[i].DxSGroup = 0x01; /* Put 0x00 to disable the DES on these pins */
#endif
 enableInterrupts();
 * @brief Adjustable led blinking speed using touch sensing keys
 * KEY1: LED1 is blinking
 * KEY1: LED1 is blinking faster
 * KEY1: LED1 don't blink anymore
 * @par Parameters:
 * None
 * @retval void None
 * None
 if ((TSL_GlobalSetting.b.CHANGED) && (TSLState == TSL_IDLE_STATE))
  TSL_GlobalSetting.b.CHANGED = 0;
  if (sSCKeyInfo[0].Setting.b.DETECTED) /* KEY 1 touched */
   BlinkSpeed++;
   BlinkSpeed = BlinkSpeed % 3;
 switch (BlinkSpeed)
  case 0 :
   GPIO_WriteHigh(GPIOD, GPIO_PIN_0);
   break;
  case 1 :
   if (TSL_Tick_Flags.b.User1_Flag_100ms == 1)
    Delay(&Toggle, 2*MilliSec);
   break;
  case 2 :
    Delay(&Toggle, 1*MilliSec);
   break;
  default :
    Delay(&Toggle, 1*Sec);
 * @brief Configures clocks
 * @par Parameters:
 * None
 * @retval void None
 * None
 /* Fmaster = 16MHz */
 CLK_HSIPrescalerConfig(CLK_PRESCALER_HSIDIV1);
 * @brief Configures GPIOs
 * @par Parameters:
 * None
 * @retval void None
 * None
 /* GPIOD reset */
 GPIO_DeInit(GPIOD);
 /* Configure PD0 (LED1) as output push-pull low (led switched on) */
 GPIO_Init(GPIOD, GPIO_PIN_0, GPIO_MODE_OUT_PP_LOW_FAST);
 if ((CheckFlag) != 0)
  NumberOfStart = NumberofTIMCycles;
 if (NumberOfStart != 0)
  CheckFlag = 0;
 if (TSL_Tick_Flags.b.User1_Flag_100ms)
  TSL_Tick_Flags.b.User1_Flag_100ms = 0;
  NumberOfStart--;
 if (NumberOfStart == 0)
  action();
  CheckFlag = 1;
void Toggle(void)
 GPIO_WriteReverse(GPIOD, GPIO_PIN_0);
/****************** (c) 2008 STMicroelectronics ******************************/
0 REPLIES 0
