2014-02-20 5:13 AM
Hi all,
I cannot find what the meaning is of those E/H/L parts of the address! Nowhere in the datasheets are the abbreviations explained. I presume H and L are the High and Low ockets but what is E?I don't understand why you want to put the high byte before the middle byte.Can somebody clarify?Regards.An #flash-programming-stm8s2014-02-21 9:15 AM
Hi!
E stands for ''extended''; H stands for ''high'' and L stands for ''low''. If $123456 is an address, E = $12; H = $34 and L=$56. regards EtaPhi2014-03-06 2:23 AM
Thanks alot EtaPhi! :)
