After the STM8L152K6 device is programmed by swim, it must be turned off and then on again for normal operation
gkim.19
After the STM8L152K6 device is programmed, it must be turned off and then on again for normal operation. However, if the STM8L152K6 device resets by pressing the Reset button after programming, it does not work. I have to do the power on reset once after programming, and after that, I reset it by pressing the reset button and it works normally. For my project, power on reset is not easy because the battery is built-in.
I will wait for your answer.
Thank you.
0 REPLIES 0
