ioc file not generating
  • July 15, 2025
  • 6 replies
  • 1185 views
hi i have been trying to configure mcu of h745BIT3 208 pin, IOC file is not generating, and i have tried for g4 series same issue happening today only, is there any server down or update have to do.
regards,
srinath
Best answer by Ghofrane GSOURI
Hello @Srinath_03
Actually, @Andrew Neil ’s reply is very helpful. Please check the provided links and try the suggested workaround; it should help you resolve the issue.
I will be waiting for your feedback.
THX
Ghofrane
Ghofrane GSOURI
Hello @Srinath_03
Could you please provide more details about STM32CubeIDE version that you are using also your OS.
THX
Ghofrane
windows 11 and stm32cube ide version 1.16.1
 and my friend's laptop windows 11 and version 1.17 both the systems IOC file is not generating
regards,
srinath
Ghofrane GSOURI
Ghofrane GSOURIBest answer
Hello @Srinath_03
THX
Ghofrane
Andrew Neil
hi @Andrew Neil thanks for your response it solved the issue after updating the cube ide.
regards,
srinath
