Problem with an application using the graphical subsystem weston on the STM32MP157F-DK2 board
Forti61
In the file "Problem description.pdf" you find a description of my problem.
I am using visualgdb to compile a Linux application using the GTK-Graphic running on the A7 core of the STM32MP157F-DK2 board.
The build process principally works correctly, but there is a problem with user privilege settings.
Does sombedy have any ideas how to tackle this problem ?
Erwan SZYMANSKI
Hello @Forti61,
The behavior you have looks completely normal, and your PDF well summarize it :
  • Graphical application cannot be executed by root user, but only by weston.
  • If your IDE execute your program as root user, it will not work
I do not know your editor, but you certainly have a way to execute your program with a different user privilege.
Kind regards,
Erwan.
