STM32WL5MOC with external antenna
malkavit6
Hi all,
I designed a sensor board with STM32WL5MOC based on B-WL5M-SUBG1. Due to other constraints I cannot place the antenna directly on the PCB. Therefore I would like to place an U.FL connector (like: https://www.digikey.hu/en/products/detail/hirose-electric-co-ltd/U-FL-R-SMT-1-80/3978495) on the PCB and using an external antenna (like: https://www.digikey.hu/en/products/detail/te-connectivity-linx/ANT-868-PML-UFL/5592353).
My question is that, if I follow the design guidelines given in the datasheet of STM32WL5MOC (see 3.4.3.3 point), then can I use this solution? In the datasheet it is also stated that "FCC implies that the antenna must be
stuck to the board connector with epoxy glue".
Thank you for your comments and suggestions!
0 REPLIES 0
