STM32L073RZ-Nucleo LoRaWAN Communication stop after 24 hour..??
BHANU RATHORE
Hi greetings,
I am using Murata module with STM32CubeExpansion_LRWAN_V1.3.1 STM32L073RZ-Nucleo code. with below details
1. GATEWAY KERLINK
2. CLASS C
3. UPLINK and Downlink
4. Loriot Network Server
communication is going well. but after fix 24 hour I am not able to receive data at network server side.
and in case of B-L072Z-LRWAN1 code with development board I not face this issue.
last from loriot networkside a DevStetusReq 06 {} command transmit from network server side after then no communication happen end node stuck after hard reset again work.
please suggest how to continuous communication enable in STM32L073RZ-Nucleo Hw.
BHANU RATHORE
solved
it was stuck through downlink command devstatusreq
BHANU RATHORE
solved
