Regarding the use of X-CUBE-MATTER, how should NodeLabel, ManufacturingDate, and UniqueId be set?
AkihiroN
In X-CUBE-MATTER, how are the Basic Information Cluster attributes NodeLabel, ManufacturingDate, and UniqueId configured? Are they fixed values, or does the user need to implement their setting? Also, are these set using the ZAP Tool?
Regarding UniqueId, I believe a truly unique value should be used. Is it implemented that way currently, or does this functionality need to be added?
0 REPLIES 0
