I want to use the en.x-cube-subg1_firmware for the X-NUCLEO-IDS01A5 (based on SPSGRF-915) expansion board. I'm a novice and struggling to identify hardware specific files adaptations vs the example project (for example STM32L152RE-Nucleo)
FRozy.1
I am wanting to use stm32L476rg - a nucleo decelopment board that does not include SPSGRF. I am working on learning to communicate via SPSGRF from the nucleo to the STM32 IOT discovery kit - which includes SPSGRF integrated.
Please comment on what files or code you would look at to integrate this library. The readme in the P2P_demo folder only tells me that it is easy to do - and it probably is. I'm using Keil in case that matters.
Thank you in advance for your time.
Frank
https://www.st.com/en/ecosystems/x-nucleo-ids01a4.html#tools-software
0 REPLIES 0
