Hi every body I have two b_L072z_LoRaWAN module, I want to make lora peer 2 peer communication, one as transmitter and the other as a receiver , I don't know if the ping pong example is suitable for use, and how can I modify it to make a Tx or a Rx
BMaha.2
or if I must write my own code, how to do it
Thank you,
Yes, the Ping-Pong example would make a good starting point and should be easy enough to fork into two projects / modes
Thank you very much
