stemwin flicker
Rahimi.Meysam
Posted on June 23, 2015 at 17:19
Hi.
Im using stemwin library and for example an Iconview widget.
my problem is that when i change the selection iconview an flicker is viewed.
im using fsmc that is fast enough(i think).
I read somewhere that by using memory device problem will be solved but in stemwin user manual mentioned that memory device is active by just set one parameter to one..
can any body help me.
thank you
#stemwin
0 REPLIES 0
