Periphiral module using DMA2
ch2
Posted on February 20, 2014 at 06:32
Hello.
I am working on a project in which i have to grab data from DCMI and store it to SDIO. Both of these periphirals are using DMA2. I have tested SDIO and it is perfectly working with DMA2. Now i have a bit of confusion that how data is handled; if both of the periphiral modules are using DMA2. What are the chances of losing data? If any body has done this before kindly share your experience.
#dcmi-dma-camera #dma2 #sdio
Posted on February 20, 2014 at 16:01
DMA2 has multiple streams, your primary issue is likely to be the disparity of In Flow and Out Flow rates of your respective devices.
