Designer Run Simulator error!
lxw
0690X000009878ZQAQ.pngI used cubemx to generate the project, using designer generate gui code. This project works well in VS, MDK and development boards.But use run simulator in designer to prompt the errors shown in the figure.Excuse me, where did this go wrong, how should revise.Thank you very much!
10 REPLIES 10
No problem! Let me know if it happens again. I only ever see this if i've accidentally reverted certain files without having my new views under version control (this means they won't get their size evaluated).
/Martin
