Crypto lib - STM32 crpto lib vs Openssl
s-shige
Posted on August 31, 2016 at 18:29
Hello, Admin and everyone.
Please let me ask,
Can we use Openssl with STM32 nucleo board ? if possible, how ?
I cannot read the lib on Keil.
and can we migrate from Opennssl to STM32 crypto lib ?
Thanks.
#stm32-crypto-openssl
Walid FTITI_O
Senior II
Posted on September 01, 2016 at 13:38
Hi s-shige,
YEs you can , just enable the CRC before using the crypto lib and ensure that the CRC and CRYP Enable macros are uncommented in the hal_conf.h :
Check:
in hal_conf.h enabled:
 #define HAL_CRC_MODULE_ENABLED
 #define HAL_CRYP_MODULE_ENABLED
in your init function:
 /* Enable CRC clock */
  __CRC_CLK_ENABLE();
-Hannibal-
s-shige
Posted on September 02, 2016 at 18:47
Hello, Hannibal.
Please let me confirm and ask again.
Does it mean that ST32 cyrpt lib comatible with Openssl, right ?
I can use Openssl apps with ST32 cyrpt lib with your configuration.
Is my understanding correct ?
Shigenori
Posted on September 02, 2016 at 19:18
I think you'll need to evaluate how easy it is to port, the algorithms are clearly the same, and defined, but the interfaces to various API, and the functionality at a hardware level (data length, alignment, etc) tend to complicate things.
I'm not sufficiently familiar with OpenSSL to know it's needs, but the ST code does work.
