why does my linear sensor array not scale/normalize?
‎2017-06-30 6:57 AM
I'm using STM Studio to tune my linrot (linear) sensors according to this application note:
'AN4316 Application note Tuning a STMTouch-based application'
I did this before and it appeared to work. However with this new board revision and new code it does not.
Here is the complete code
https://gist.github.com/netskink/ec3cc4078d20be0f2fb56a67fa50f10d
Here is how I am calculating the coefficients:
https://docs.google.com/spreadsheets/d/1YOwbyMmguZp7F6Dv12cmRwLbypxmPJXVZTNRgd-RVTA/edit?usp=sharing
Here is the relevant portions of the code with some comments:
tsl_conf.h has enabled use of the coefficients
#define TSLPRM_LINROT_USE_NORMDELTA (1) // does this need to be set to use coefficients?
tsl_user.c has been tested with and without the modified coefficients
// Default
//CONST uint16_t MyLinRot0_DeltaCoeff[5] = {0x0100, 0x0100, 0x0100, 0x0100, 0x0100};// calculated//CONST uint16_t MyLinRot0_DeltaCoeff[5] = {0x15c, 0x13b, 0x158, 0x138, 0x100}; // CH0, CH1, CH2, .. CH4// Tweaked to make coefficent[2] greater than calculated to attempt to raise its level.CONST uint16_t MyLinRot0_DeltaCoeff[5] = {0x15c, 0x13b, 0x1b8, 0x138, 0x100}; // CH0, CH1, CH2, .. CH4Here are some videos demoing the results
https://www.youtube.com/playlist?list=PLisMMQz00ChxAAp2NwkWGzTL_J7hTVne2
‎2017-07-05 6:54 AM
Bump to keep alive. I still have not resolved this issue.
‎2017-07-08 3:22 PM
bump again to keep active. I still have this problem unresolved. If you know of additional info I can post to help explain the problem please let me know.
‎2017-07-08 6:03 PM
Not sure who covers Touch Sensor stuff here. The sensor forum seems more chip related, some of the FAE's have to have some customer exposure to this area. Perhaps one of the marketing staff can poke an appropriate engineer?
https://community.st.com/community/mems-sensors-community/mems-sensors-forum
‎2017-07-09 7:38 AM
Thanks Clive. I'll repost to that group.
