What is the quickest way to read option bytes value in PIC32L1?
Wonder Cakes
Posted on June 20, 2017 at 13:40
I'm using STM32L1, and I would like to read out the option bytes values to make sure I was able to lock the read option of the memory.
What is the quickest way to do so ?
Thank you.
Zt Liu
Senior III
Posted on June 20, 2017 at 15:49
Hi Wonder Cakes!
if you are using hal libraies, check your Cube example\Flash\Flash_WriteProtection Folders,
It goes like this
FLASH_OBProgramInitTypeDef OptionsBytesStruct;
HAL_FLASH_Unlock();
HAL_FLASH_OB_Unlock();
HAL_FLASHEx_OBGetConfig(&OptionsBytesStruct);
Is that what you want?
