WARNING: CPU random generator seem to be failing, disable hardware random number generation
WARNING: RDRND generated: 0xffffffff 0xffffffff 0xffffffffff 0xffffffffffffff
‎2023-02-11 1:52 AM
Hello community,
since I updated the STM32 Cube IDE the following problem is displayed when entering the run or debug session.
Have you had this before and possibly already a solution for it?
with kind regards
Tim
‎2023-02-11 3:25 AM
Thank you for your answer :)
you are right, it was a problem on my host PC.
i have fixed the Problem on myself with a Bios Update from my mainboard.
https://arstechnica.com/gadgets/2019/10/how-a-months-old-amd-microcode-bug-destroyed-my-weekend/
with kind regards
Tim
‎2023-02-11 3:16 AM
Looks like a bug on your host PC: https://www.reddit.com/r/AMDHelp/comments/itfgf4/cpu_random_generator_seem_to_be_failing/
hth
KnarfB
‎2023-02-11 3:25 AM
with kind regards
Tim
