Using ST-Link with Keil
Options
‎2010-01-14 12:00 AM
Posted on January 14, 2010 at 09:00
5 REPLIES 5
Options
‎2011-05-17 4:38 AM
Posted on May 17, 2011 at 13:38
I have been using the ULink - me for debugging and programming but due to a couple of failures, decided to look for an alternative. Been trying to get the ST-Link to work with Keil u-vision 4, after connecting the device the red com light came on and all seemed to be well. changed the keil debug and utilities configuration to use the ST-Link. I then tryed to program and the com light starts to flash but then stops and keil hangs on load and does not program the device. Any ideas??Options
‎2011-05-17 4:38 AM
Did u succeed in this?Options
‎2011-05-17 4:38 AM
Options
‎2011-05-17 4:38 AM
Did find the problem? Same here ... IAR works fine. Keil 4.x dont...
Options
‎2011-05-17 4:38 AM
Yes, I have succeeded in this. I updated the STlink firmware version from and also upgraded the Keil IDE to 4.10.
