USB Audio Device Class (speaker + mic) on STM32F4-Discovery
gaurav2
Posted on June 28, 2016 at 20:52
I have looked around on ST website and the forums for getting playback and record working on STM32F4-Discovery board. I only found the playback and record example that uses the FatFs and the USB storage device.
However, I want to get the USB Audio class working where I want to use the Discovery board for both uplink and downlink, i.e., the board should like a speaker and mic to a Windows Host PC via USB. Does anyone have this working and wouldn't mind sharing some pointers? I saw a post from maggie.roxas who got the speaker portion working but I don't see anyone with Microphone working over USB.
Any pointers greatly appreciated. Thanks much.
Walid FTITI_O
Senior II
Posted on June 29, 2016 at 13:24
Hi gaurav_stm,
I recommend you check the ''Audio_Speaker'' example in ''
http://www.st.com/en/embedded-software/stsw-stm32html
'' at this path STM32_USB-FS-Device_Lib_V4.0.0\Projects\Audio_Speaker.
The USB-FS-Device Audio Speaker demo gives examples of how to use the USB-FS-Device peripheral to communicate with the PC host in the isochronous transfer mode.
It provides a demonstration of the correct method for configuring an isochronous
endpoint, receiving or transmitting data from/to the host.
Otherwise, you can search for code example from forum users like this
https://my.st.com/public/STe2ecommunities/mcu/Lists/STM32Discovery/Flat.aspx?RootFolder=https://my.st.com/public/STe2ecommunities/mcu/Lists/STM32Discovery/Audio%20Class%20USB%20-%20no%20data%20-%20STM32F4Discovery&FolderCTID=0x01200200770978C69A1141439FE559EB459D75800084C20D8867EAD444A5987D47BE638E0...
, or in github community like this
https://github.com/LonelyWolf/stm32/tree/master/usb-mic
which would be helful for you.
-Hannibal-
