Unlocking flash memory (PELOCK bit) on STM32L051T6
Damiano Balzani
Posted on March 28, 2018 at 10:35
Hi eveerybody,
I'm tryng to use the protections against unwanted write/erase operations reported on 3.4.3 of Reference manual.
When my program runs the memory is locked (PELOCK BIT = 1) and i want to unlock it.
There is an examole code on reference manual. I copied it on my code but it doesn't work.
This is my code:
while ((FLASH->SR & FLASH_SR_BSY) != 0) /* (1) */
   add here time-out management */
if ((FLASH->PECR & FLASH_PECR_PELOCK) == 0) /* (2) */
     if ((FLASH->PECR & FLASH_PECR_PRGLOCK) != 0) /* (3) */
         FLASH->PRGKEYR = 0x8C9DAEBF;
         FLASH->PRGKEYR = 0x13141516;
         FLASH->PECR &= !FLASH_PECR_PELOCK;
Do i miss something? clocks or enable maybe??
Generally how can i access to FLASH -> PECR register?
Thanks in advance
Damiano
#pelock
0 REPLIES 0
