Unexpected error, can't add new hex file
Bill Berkan
Posted on June 05, 2018 at 21:27
I need help loading a new hex file.  I keep getting unexected error.  I am not an engineer and I am glad to pay for assistance.
9 REPLIES 9
Nesrine M_O
Lead II
Posted on June 06, 2018 at 10:27
Hi
bill.pbs
  1. What are you using as STM32 product?
  2. Which
    hex file
    did you looked to?
  3. '
    I keep getting unexected error' what kind of error you are facing?
  4. What is your IDE version?
  5. Could you please provide more explanation on your case, so that it will be easier to understand the issue?
-Nesrine-
AvaTar
Lead
Posted on June 06, 2018 at 11:02
I guess that means Flashing (programming).
Which tool ?
The exact error message would be helpful.
Posted on June 06, 2018 at 11:26
Replace the USB cable
Posted on June 06, 2018 at 12:57
What tool generated the error?
What tool generated the .HEX file?
Posted on June 06, 2018 at 15:13
Hi Nesrine
Thank you for your reply. First,let me tell you I know very little about
this situation. I am an old guy who owns a small business, we make
laminating machinery, devices used for laminating maps, menus, etc. I had
a board designed to control speed. The guy who designed it can't seem to
figure out the problem. The hex file I am trying to load was written by
him to address a few small issues in the original file. I have not used
this system before but have had experience using a similar program for Pic
chips from Microchip. I studied the ST Link stuff and hooked up the pcb as
instructed. After a few small issues it seemed I think I was able to
connect the pcb to the software. Each time I press erase the pcb is
disconnect from the s/w and I get the unexpected error. When I click on
that I get the write protected error.
I have attached several screen shots that seem to answer some of your
questions, including a shot of the log which seems to identify the st link
v2, the chip, etc. The new hex file is written by the guy who wrote the
original one, I am guessing he just changed some code in the original that
needed modification as requested.
Does any of this make any sense?
Thank you
Bill
On Wed, Jun 6, 2018 at 2:28 AM, Nesrine M <st-microelectronics@jiveon.com>
________________
Attachments :
ER4.txt.zip : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HxXT&d=%2Fa%2F0X0000000azY%2FSVyk_s_KdG1wW.V4vJVMfdmFjZcYrI.tK8uVgVSkJOw&asPdf=false
ER1.PNG : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HxXO&d=%2Fa%2F0X0000000azX%2FdNelomALG4yrzQOctWmiaWSRvfpmIs_26uiZ53FR9Bg&asPdf=false
ER2.PNG : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HxX0&d=%2Fa%2F0X0000000azV%2Fi4X7oavWk6WgCUyxVkAmgdiG.c4EZAeyh9O2rdgiyBo&asPdf=false
ER3 ide.PNG : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HxXJ&d=%2Fa%2F0X0000000azT%2FzsDB2aADanYOeyCqwbBiR8h3pmJLHyxVAVFCqabyDI8&asPdf=false
Posted on June 07, 2018 at 13:19
I guess I dont know what tool means, sorry.  The code was compiled with Atollic and the device is a st link /v2.  The first message is unexpected error at which time the target is instantly disconnected from st link.  The next message is some flash pages are write protected.  It has an OK button but it is grayed out.  Thank you
Posted on June 07, 2018 at 13:20
Thank you for the idea, but same results.
Bill
Posted on June 07, 2018 at 13:22
I am not sure about all of your terminology but the code was compiled with Atollic and the tool I am using is ST LINK /V2.  I hope these are the right answers.  Thank you, Bill
Posted on June 07, 2018 at 13:32
As your first image shows, the 'ST-Link Utility'.
You can try to configure the 'option bytes', and remove the write protection for sectors marked as such.
See the ST-Link Utility manual, as found here:
http://www.st.com/resource/en/user_manual/cd00262073.pdf
Section 3.6 covers this topic.
Try a mass erase again, and then program.
I haven't myself dealt with write-protection on STM32 devices.
