Toggle with output compare
ari_v
Posted on March 03, 2008 at 10:30
ari_v
Posted on May 17, 2011 at 12:25
I'm trying to toggle a pin at a specific sequence and must be very accurate.
Therefore, I want to use the output compare with TIM3 CH4.
All I want to do is to load the TIM3->CCR4 register with required value, wait until compare event occurs, then load next interval value to CC4, and so on. I do not want to use interrupt, and I want CH4 to toggle the associated pin (PB1) automatically when compare event occurs.
From some reason I did not succeed to do this simple task. Could anyone assist?
Thanks,
Ari
