Tim1 Channel 4 Porblem
ezrab
Posted on June 27, 2011 at 08:32
hi.
i am tring to activate 3 chanel as ''6-step PWM generation'' with Dead time and afourth channel as stady 50% duty cycle .
for some reason when i activate the Fourth Channel it disraps the other three.
why?
here is the code:
   TIM1->ARR=1600; /* Set the Autoreload Register value (Count/f)=(1/(wanted freq))*/
    TIM1->EGR=TIM_EGR_UG;/*!<Update Generation */
//channel 1 PA8 PB13
    TIM1->CR2=TIM_CR2_OIS1  ; /*!<Output Idle state 2 (OC2 output) */
    TIM1->CCMR1=TIM_CCMR1_OC1M ;  /*!<OC1M[2:0] bits (Output Compare 1 Mode) */
    TIM1->CCR1=800; /* Set the Capture Compare1 Register value (Duty Cycle)*/
    TIM1->CCER=TIM_CCER_CC1E |TIM_CCER_CC1NE | TIM_CCER_CC1P  | TIM_CCER_CC1NP  ; /*!<Capture/Compare 1 output enable */
//channel 2 PA9 PB14
    TIM1->CR2|=TIM_CR2_OIS2  ; /*!<Output Idle state 2 (OC2 output) */
    TIM1->CCMR1|=TIM_CCMR1_OC2M ;  /*!<OC1M[2:0] bits (Output Compare 1 Mode) */
    TIM1->CCR2=800; /* Set the Capture Compare1 Register value (Duty Cycle)*/
    TIM1->CCER|=TIM_CCER_CC2E |TIM_CCER_CC2NE | TIM_CCER_CC2P  | TIM_CCER_CC2NP ; /*!<Capture/Compare 1 output enable */
     TIM1->CR2|=TIM_CR2_OIS3  ; /*!<Output Idle state 2 (OC2 output) */
    TIM1->CCMR2|=TIM_CCMR2_OC3M  ;  /*!<OC1M[2:0] bits (Output Compare 1 Mode) */
    TIM1->CCR3=800; /* Set the Capture Compare1 Register value (Duty Cycle)*/
    TIM1->CCER|=TIM_CCER_CC3E |TIM_CCER_CC3NE | TIM_CCER_CC3P  | TIM_CCER_CC3NP ; /*!<Capture/Compare 1 output enable */
    TIM1->CR2|=TIM_CR2_OIS4  ; /*!<Output Idle state 2 (OC2 output) */
      TIM1->CCMR2|=TIM_CCMR2_OC4M ;  /*!<OC1M[2:0] bits (Output Compare 1 Mode) */
    TIM1->CCR4=800; /* Set the Capture Compare1 Register value (Duty Cycle)*/
   TIM1->CCER|=TIM_CCER_CC4E | TIM_CCER_CC4P  ; /*!<Capture/Compare 1 output enable */
    TIM1->CCMR1|=TIM_CCMR1_OC1PE ; /*!<Output Compare 1 Preload enable */
    TIM1->CR1=TIM_CR1_ARPE; /*!<Auto-reload preload enable */
    TIM1->BDTR=TIM_BDTR_OSSR| TIM_BDTR_OSSI | TIM_BDTR_LOCK_0 | 80 | TIM_BDTR_BKE | TIM_BDTR_BKP | TIM_BDTR_AOE;
     TIM1->CR1=TIM_CR1_CEN;  /*!<Counter enable */
    TIM1->BDTR=TIM_BDTR_MOE;
thanks for your help.
0 REPLIES 0
