STM32F40G_eval+linux+eclipse+code sourcey
dorrachendoul
Posted on April 12, 2013 at 11:41
Am programming my stm32 using eclipse on linux, i configured link resources and i added path, but am having this error:
Program ''arm-none-eabi-gcc'' not found in PATH
I don' know why i have this error because i think that i' ve added :
- path in properties -> environnement and in discovery otions.
isn't it enough.
Can someone pease help me.
10 REPLIES 10
Posted on April 12, 2013 at 15:45
If you open a console can you run it from the command line?
Is it installed properly?
What's in your PATH environment variable?
dorrachendoul
Posted on April 12, 2013 at 16:27
the path is :
/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/home/user /CodeSourcery/Sourcery_G++_Lite/bin;${PATH}
Any help please?
jean-michel-62
Posted on April 12, 2013 at 23:26
Is there a space between ''user'' and ''/Codesourcery'' ?
Or is it a typo only in the message ?
dorrachendoul
Posted on April 15, 2013 at 09:55
No, there is no space
crt2
Posted on April 15, 2013 at 11:08
In Ubuntu in bashrc file you add the line - that will solve your problem:
export PATH=''$PATH'':~/CodeSourcery/Sourcery_CodeBench_Lite_for_ARM_EABI/bin/
frankmeyer9
Posted on April 15, 2013 at 11:10
There are ways to add paths permanenty (i.e. by some scripts invoked at startup), but this depends on the Linux distribution. Just use a search engine and the right key words.
The disadvantage of this method - you can have just one of this toolchains who name their binaries arm-none-eabi-xxx, because it whould overshadow all others. Configuring your IDE would be the better way.
dorrachendoul
Posted on April 15, 2013 at 11:18
I added the line but i still have this error :
dorrachendoul
Posted on April 15, 2013 at 11:23
I ve already configured it .
in Arm sourcery Linus GCC Assembler i ve browsed  :/home/dorra/CodeSourcery/Sourcery_G++_Lite/bin/arm-none-eabi-as
and in Arm sourcery Linus GCC C compiler i ve browsed: /home/dorra/CodeSourcery/Sourcery_G++_Lite/bin/arm-none-eabi-gcc
jean-michel-62
Posted on May 03, 2013 at 20:53
Sorry for replying so late, but could you try the commands :
arm-none-eabi-gcc -v
and,
which arm-none-eabi-gcc
in a terminal ?
If the first one if sucessfull,it means the compiler is available to the system; and in such a case, the second command will tell you where's the compiler file.
I also recommend you to keep automatic discovery of the toolchain ...
Hope this helps !
