STM32F3Discovery fails to program
aidos
Posted on August 08, 2015 at 15:02
When I try to program my board using OpenOCD 0.8.0, I've get:
Open On-Chip Debugger 0.8.0 (2014-10-25-15:24)
Licensed under GNU GPL v2
For bug reports, read
http://openocd.sourceforge.net/doc/doxygen/bugs.html
srst_only separate srst_nogate srst_open_drain connect_deassert_srst
Info : This adapter doesn't support configurable speed
Error: open failed
in procedure 'transport'
Runtime Error: extra/stm32f3-openocd.cfg:5:
in procedure 'script'
at file ''embedded:startup.tcl'', line 58
in procedure 'init' called at file ''extra/stm32f3-openocd.cfg'', line 5
More detailed report of the command
'strace openocd -f board/stm32f3discovery.cfg -f extra/stm32f3-openocd.cfg -c ''stm_flash `pwd`/main.bin'' -c shutdown' is
http://pastebin.ru/PFNTJuZP
Here is my
https://github.com/mblythe86/stm32f3-discovery-basic-template/blob/master/extra/stm32f3-openocd.cfg
How to do total hard reset?
#openocd #c-programming
Posted on August 10, 2015 at 17:08
Hi diakonov.igor,
1-Could you check your ST-Link driver?
2-What do you mean exactly by ''How to do total hard reset?'' ? if I understand your question, the reset buttom is dedicated to this issue.
-Shahrzad-
