STM32F101-Global interrupt enable/disable
bozorgzad
Posted on December 10, 2009 at 06:26
bozorgzad
Posted on May 17, 2011 at 13:05
Hi
I want to have control on global interrupt,but I couldnt find any register for it,what I want is to have a control to disable all of the interrupts at the same time using one cycle instruction.Will appreciate for your help
16-32micros
Hi bozorgzad,
Refer to this FAQ :
http://www.st.com/stonline/faq/faqview.php?ids=1246
Cheers,
STOne-32.
[ This message was edited by: STOne-32 on 09-03-2009 18:36 ]
per239955_stm1_st
Nowadays with 3.x version of the library the functions are defined in core_cm3.h and are named:
__disable_irq();
__enable_irq();
Short info about the functionality can be found in CMSIS_Core.htm document (provided with the library). More info on page 18-19 in the PM0056 doc. (15491.pdf manual april 2009 version).
Best regards,
Per
