STM32Cube FreeRTOS cmsis_os.c osPoolAlloc bug
rmawatson
Posted on November 11, 2015 at 18:58
This code generated by STM32Cube with FreeRTOS looks like it has a bug.
To reproduce, create a small pool. Allocate a single item that is not free'd then, allocate and deallocate sucessive items. The pool will stop allocating, even though there are free slots.
The code at fault is,
    index = pool_id->currentIndex + i;
    if (index >= pool_id->pool_sz) {
      index = 0;
currentIndex is never reset, and so for a queue size of say 8, if currentIndex = 7, then for all i (1,2,3..) in the loop, currentindex + i will be greater than pool_sz. and index will be set to 0, so only markers[0]  gets checked continiously. If index 0 is not free, then the pool will not allocate, and will break in this condition
The above section should be something like
index = (pool_id->currentIndex + i) % pool_id->pool_sz;
FULL FUNCTION:
void *osPoolAlloc (osPoolId pool_id)
  int dummy = 0;
  void *p = NULL;
  uint32_t i;
  uint32_t index;
  if (inHandlerMode()) {
    dummy = portSET_INTERRUPT_MASK_FROM_ISR();
  else {
    vPortEnterCritical();
  for (i = 0; i < pool_id->pool_sz; i++) {
      index = 0;
    if (pool_id->markers[index] == 0) {
      pool_id->markers[index] = 1;
      p = (void *)((uint32_t)(pool_id->pool) + (index * pool_id->item_sz));
      pool_id->currentIndex = index;
      break;
    portCLEAR_INTERRUPT_MASK_FROM_ISR(dummy);
  else {
    vPortExitCritical();
  return p;
thomfischer
Posted on November 12, 2015 at 10:44
maybe there is another error in function
osPoolCAlloc
void
osPoolCAlloc
osPoolId
pool_id)
void
*p = osPoolAlloc(pool_id);
if
(p != NULL)
memset
(p, 0,
sizeof
(pool_id->pool_sz));
ERROR this is size of uint32_t = 4
memset
(p, 0, pool_id->
item_sz
should be
return
p;
my proposel for
osPoolAlloc()
void
osPoolAlloc
osPoolId
pool_id)
int
dummy = 0;
void
*p = NULL;
uint32_t
i;
uint32_t
index;
if
(inHandlerMode()) {
else
index=pool_id->
currentIndex
// +++ new
for
pool_sz
; i++) {
// index = pool_id->currentIndex + i; // --- old
if
(index >= pool_id->
pool_sz
index = 0;
if
(pool_id->
markers
[index] == 0) {
pool_id->
markers
[index] = 1;
p = (
void
uint32_t
)(pool_id->
pool
item_sz
pool_id->
currentIndex
= index;
break
index++;
// +++ new
if
(inHandlerMode()) {
else
return
p;
maybe in
osPoolFree
currentIndex
could be set to the last freed block, so
alloc does not need to search for a free block.
osStatus
osPoolFree
osPoolId
pool_id,
void
*block)
uint32_t
index;
if
(pool_id == NULL) {
return
osErrorParameter
if
(block == NULL) {
return
osErrorParameter
if
(block < pool_id->
pool
return
osErrorParameter
index = (
uint32_t
)block - (
uint32_t
)(pool_id->
pool
if
(index % pool_id->
item_sz
return
osErrorParameter
index = index / pool_id->
item_sz
if
(index >= pool_id->
pool_sz
return
osErrorParameter
pool_id->
markers
[index] = 0;
pool_id->currentIndex=index; // +++ next
alloc
will get this free block
return
osOK
A better solution would be to use a linked list with free memory packets.
This would avoid searching for a free packet on allocation.
best regards
