STM32Cube errata?
uc2013135191
Posted on July 18, 2016 at 00:20
Hi everyone,
So I would like to test out a bit of the STM32Cube. But first I was looking for a bug list on current versions so I don't run into a stupid problem and get stuck for hours.
Is there a errata for the STM32Cube? If there is, where can I find it?
slimen
Posted on July 18, 2016 at 13:24
STM32Cube doesn't share a bug list, the Release note precise only the corrections/Main Changes done for each release.
For STM322CubeMx, you can find in this
http://www.st.com/content/ccc/resource/technical/document/release_note/b2/02/4b/e3/81/32/49/c4/DM00107607.pdf/files/DM00107607.pdf/jcr:content/translations/en.DM00107607.pdf
, the bug list fixed for each release with Known problems and limitations.
