STemwin GUIDRV_SPage
peeyush
Posted on February 10, 2016 at 07:53
Hi dear members,
I want to interface jhd12864 lcd using Stemwin library, The  segger document says that you can configure the KS0108 driver in the run time using GUIDRV_SPage.
But GUIDRV_SPage.h file is not included in Stemwin distribution..Please help me out in this.
4 REPLIES 4
pbakker
Posted on February 10, 2016 at 18:07
Similarly, working with STMCube_FW_L1_V1.40, STemWin version 5.28 is included. The documentation states that run-time configurable driver GUIDRV_SPage is included.
However, there is no GUIDRV_Spage.h file in the document tree Middlewares\ST\STemWin. There is no prototype for run-time configuration GUIDRV_SPage_Set1502().
It appears that the STemWin included in STMCube L1 is incomplete.
pbakker
Posted on February 25, 2016 at 20:49
Required drivers for use with STemWin can be purchased from SEGGER for $$$.
mmetzger
Posted on September 12, 2016 at 13:46
In the manual, the driver is described. In that case, in my understanding, it should be included!!!!!!!!!!!!!!!
Same problem!
slimen
Posted on September 14, 2016 at 17:36
Hi metzger.marco,
Could you please precise which controller and firmware version are you using ?
You can check in the emwin user manual (or through this
https://www.segger.com/emwin-guidrv-spage.html
) if your display controller is supported by GUIDRV_SPage driver.
