2013-10-27 8:24 PM
I was interested in trying Espruino software on an STM32F4 and downloaded ST-Link.
Unfortunately, when I try to run STM32 ST-Link Utility.exe I get a dialog''This application was unable to start correctly ()xc000007b). Click OK to close the application.''Am I invoking it correctly? Or is there some sort of setup I need to do before starting up?The IAR embedded workbench seems to have no problem dow loading to this board.2013-10-28 6:38 AM
Hard to say, running fine here, stand-alone and with Keil. Mostly on Win7 64-bit machines running pro and ultimate.
Check you have current drivers/firmware/utilities. Check you have appropriate 32/64-bit drivers. Check that IAR isn't currently using/connected to the ST-LINK Check you have administrative rights, no issues with USB attachment or Anti-Virus, or Daemon Tools.
