2018-04-10 2:09 PM
Hi all! Developers st-link utility external loader describe the order of creating your external bootloader under sw4stm32.
2018-04-10 2:42 PM
You'll need to review and understand the available examples
ST-LINK Utility v4.2.0\ST-LINK Utility\ExternalLoader\N25Q512A_STM32F769I-EVAL\SW4STM32
This is a fairly difficult and complex area, the Cube Programmer app works better than the ST-LINK Utilities, but you'd want to fully test your code in a stand-alone context first.
I'm using Keil, the sub-set of developers using SW4STM32 is likely to be quite limited.
2018-04-10 3:22 PM
my attempts to test this code ended with a 'missing main' error. In the forum found a similar topic that remained unanswered.
2018-04-10 5:41 PM
The code doesn't use main(), and doesn't use a vector table, you'd need to direct the linker to use Init() as the entry point.
Please link to other threads/topics where you think they are appropriate, things tend to remain unanswered when there is a lack of experts or interest. There might be enough detail in the threads to solve the problem.
