ST_AnimatedIcon... documentation help
baev_al
Posted on April 25, 2016 at 14:42
Hi.
Is there some information (documentation) on using animated functions of STemWin package?
Thanks.
Walid FTITI_O
Senior II
Posted on April 25, 2016 at 14:52
Hi baev.alexander,
I recommend that you check the application note
http://www.st.com/st-web-ui/static/active/jp/resource/technical/document/application_note/DM00089670.pdf
''Getting started with STemwin library''.
-Hannibal-
