SPL2LL-Converter Out of memory
AFink
I'm trying to covert old drivers to new ones.
I use the SPL2LL converter tool.
Folder size to be converted is ~71MByte.
I get "Out of memory" error. What should I do?
Please fins attached snapshot.
Thanks,
Aviv
4 REPLIES 4
AFink
"Out of memory" error appears even when source code contains a single file.
Can you please guide me what to be done in order to solve this issue?
Thanks,
Aviv
Hi @AFink​ ,
Is the error message faced only when parsing the file "source/flash.c" or it isn't limited to this file?
Thanks,
-Amel
AFink
Hi Amel,
Indeed, flash.c causes a problem.
I did encounter some other problematic files, though.
Now I'm trying one-by-one, but this is too exhausting.
Attached please find flash.c, so you can investigate it.
Thanks,
Aviv
AFink
Hi Amel,
Please find attached one more file which makes problems, inetlock.c.
Thanks,
Aviv
