SDIO + DMA -> FEIF error
brubinstein
Posted on April 29, 2015 at 17:05
I didn't find way to avoid this error but ignoring it. I wasn't the first one of doing so. There is an example from Keil: .\Keil\ARM\Boards\Keil\MCBSTM32F400\RL\FlashFS\SD_File\SDIO_STM32F4xx.c
[code]
static BOOL WriteBlock (U32 bl, U8 *buf, U32 cnt) {
  /* Write a cnt number of 512 byte blocks to Flash Card. */
  U32 i;
  SDIO->DLEN    = cnt * 512;
  SDIO->DTIMER  = cnt * DATA_WR_TOUT_VALUE;
  SDIO->DCTRL   = SDIO_DCTRL_DBLOCKSIZE_3 | SDIO_DCTRL_DBLOCKSIZE_0 |
                  SDIO_DCTRL_DMAEN        | SDIO_DCTRL_DTEN         ;
  for (i = DMA_TOUT; i; i--) {
    if (DMA2->LISR & DMA_LISR_TEIF3) {
      break;
    if (DMA2->LISR & DMA_LISR_TCIF3) {
      if ((SDIO->STA & (SDIO_STA_DBCKEND|SDIO_STA_DATAEND)) == (SDIO_STA_DBCKEND|SDIO_STA_DATAEND)) {
        /* Data transfer finished. */
        return (__TRUE);
  /* DMA Transfer timeout. */
  return (__FALSE);
[/code]
If you look inside their for loop they just ignoring FEIF.
I verified that card access works (at least every time I've tried) and as I stated before I don't know any way to avoid this error.
STM errata doesn't shed light on this issue or I didn't find it...
Does anyone know the better way to deal with this issue?
Thank you.
#stm32-sdio-dma-fifo-feif
0 REPLIES 0
