RTC
ss882
Posted on August 18, 2012 at 01:26
Hello everyone..,
I am new to Embedded programming. I wanted to generate 2mins delay. I already want to use two timers in PWM input and Input capture mode simultaneously.
Can I use RTC to generate 2mins delay?
Thanking in advance,
Posted on August 18, 2012 at 04:45
On the STM32F1 you could certainly advance the RTC Alarm by 2 minutes, and keep repeating that. Hours or days could work on a similar principle.
You could mark time with the RTC interrupt, or SysTick interrupt.
ss882
Posted on August 21, 2012 at 17:23
Thanks Clive1..
will try changing the alarm time in the stdPeriph lib RTC example.
